Hob cable outside then in | Page 2 | on ElectriciansForums
Discuss Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
Swansea
Evening All another odd question (I love my customers)
There’s no 10mm or 6mm cable in their kitchen, apparently when it was wired there were all 13amp eco appliances. Anyway a new couple have bought it and want a 5 ring hob installed but the kitchen is done to a high standard so they don’t want trunking or walls chased (kitchen in single story extension. The board and job location are on the outside wall. Can I run a 6/10 mom cable through the wall outside the back inside for for the hob connections obv the cable would be aremourd or SY. Is this doable or is it a case of no can do
I would consider using conduit as it would look tidier than cable. If it’s a straight run black enamel looks good.
Is there a regulation I'm not aware of that says you can't run supplies to hobs in armoured?
I'm not really sure what you're getting at.
If it can be glanded into say a metal clad 45A switch in a sensible place, then what's the problem?
'wheres that in the regs'?
I never mentioned it's against the regs did i...?
I'm just saying really use swa on a domestic cooker hob? industrial type setup that.....like I say sometimes common sense should provail and you have to put your foot down with a customer and tell it how it is.
Using SWA externally is hardly an 'industrial type set up'. SWA is used in thousands of domestic properties.
To the OP; the cable could be SWA, NYY or in conduit. You need to see which is the most practical and sensible for the run. Is the cable that is ran externally likely to get any knocks. If it is then I would avoid NYY in that instance. And I don't think an externally mounted IP box is necessarily an ugly addition.
Explain to the customer the positives and negatives about each viable option and price accordingly.
Reply to Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
