House rewire. Unsure on terminating at Consumer Unit | Page 3 | on ElectriciansForums
Discuss House rewire. Unsure on terminating at Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hello all,
I am buying an old house in Kent (medway) and am looking to completely rewire the house. I am currently working as a trainee electrician and am on level 3 C&G. I am going to rewire the house myself as i know I can do this, but am unsure what to do when it comes to terminating it at the C.U. as i have never done this before. Would a fully qualified electrician be willing to terminate the circuits at the C.U then test it?
Any help would be great thanks.
Matt
Whenever a board is being changed by your mentor keep an eye out on what he's doing, ask questions.
They'll fairly straight forward once you've seen it being done and done a couple.
The tricky bits getting it looking spot on with the nice sweeping cables
I would be concerned about putting up a picture of breaking into the meter to put in a temporary supply.
By no means the perfect example however I'm quite proud of it
Earth to the earth bar, neutral to the neural bar. If it's a dual rcd be sure to terminate the same cable to the same side of the board.
Get yourself a cheap board as rpa said and give it a mock test with off cuts of cable.
Another tip:
When connecting up have say, upstairs sockets on one side and downstairs sockets on the other side so should a fault happen total loss of power to the house will be less likely to happen.
Best of luck
Another tip:
Best of luck
Reply to House rewire. Unsure on terminating at Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
2 3
