How do I wire a 3-way Zooz Zen21 smart switch? | on ElectriciansForums
Discuss How do I wire a 3-way Zooz Zen21 smart switch? in the USA Electrical Forum area at ElectriciansForums.net
myCharlie
Wisconsin
The following dead-end 3-way wiring diagram shows my current setup with the Zooz Zen21, but it's not working. This wiring works fine with a simple standard paddle 3-way switch that doesn't require a neutral wire. However, since the Zooz switch requires a neutral wire, I ran a white wire from the capped neutral wire from the breaker and the light switch to the neutral slot in the Zooz, but it didn't work. Is there another way to get the Zooz switch to work? Thank you in advance.
[ElectriciansForums.net] How do I wire a 3-way Zooz Zen21 smart switch?
TL;DR
How do I wire dead end 3-way switch with Zooz smart switch zen21?
Try switching your travelers, other than that it looks like it should work
To simplify everything, I ignore the second switch in the garage and just use the Zooz switch to try to turn on the light switch. I have the following wiring and it's not working. I have tried the Zooz Zen72, Zen21, and the Kasa HS200 single pole switch. All of these smart switches that requires the neutral is unable to turn the light on with the following wiring diagram.
However, if I did the same thing with the standard paddle switch but this time capped the neutral wires together since the standard paddle switch does not require a neutral wire. It works perfectly fine with this wiring.
So, what's wrong with my wiring on the smart switches? Why are all of them not able to turn the light on?
The only thing I can suggest is that perhaps the neutral wire you are running to the smart switch isn't working!
With the direct switching that works, the neutral is already provided at the light, so you're just switching the hot.
When you connect the various smart switches, if the neutral you connect to them isn't actually there, they probably won't do anything.
Do you have a multimeter to measure what's going on?
Yes, I do have a multimeter. What do I need to measure? When I turned on the light, there is electricity flow to the light but the light is not turn on.
On the Zooz Zen72 switch:
When the switch is off: Neutral to Load = 0.066v
When the switch is on: Neutral to Load = 3.340v
When the switch is on, the load wire does have power and vice versa.
Both those states are “off”
An on signal would be over 100v
Are you sure your meter is set to measure ac voltage?
I was going to suggest you measure the ac voltage on the Zooz neutral terminal with respect to ground, with the switch off and then on. There shouldn't be much voltage, say ~ 1V (if that) in both cases.
Just suggesting you check the Zooz neutral terminal is actually neutral!
And just to say the wiring you show in post #1 is not consistent with the ZEN21 instructions.
But this may not be the only problem.
The regular switch only used two wires in all the Zooz documentation I can see.
Is it possible that the actual source of power for this light is at the regular 3-way switch, and what you are assuming is power at the Zooz is actually a traveller to the other switch?
Zooz switch off:
Line to Load = 121.2v
Line to Neutral 121v
Load to Neutral = 0.066v
Load to Ground = 0.0073v
Neutral to Ground = 0.009v
Zooz switch on:
Line to Load = 116.3v
Line to Neutral = 121v
Load to Neutral = 3.382v
Load to Ground = 3.349v
Neutral to Ground = 0.012v
I know for sure that the other switch and the light is not the source of the power. I've measured the voltage of those wires already.
Reply to How do I wire a 3-way Zooz Zen21 smart switch? in the USA Electrical Forum area at ElectriciansForums.net
brilliant thanks for your support. Lee
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
