We still have some PILK cables in my area, any idea what era these date back to?
I tested a series of 3 columns wired in PILK the other day and the IR was >200 LN LE NE , my engineer told me afterwards these were the oldest in our county!
eh?....Hello everyone, Well it very hard Job to work with SWA and most difficult is to terminate it. It is required that all connections must be correctly terminated using appropriate termination glands. Some proper glands are needed to terminate it. Like earth tag washer fitted between gland and glanded plates or enclosure.
a bit half way house is this...Hello everyone, Well it very hard Job to work with SWA and most difficult is to terminate it. It is required that all connections must be correctly terminated using appropriate termination glands. Some proper glands are needed to terminate it. Like earth tag washer fitted between gland and glanded plates or enclosure.
Going back the late 60’s early 70’s there were Al tape armoured 3 & 4 core solidal cables.
They were awful to work with.
If you go back even further, steel tape armoured. They would slice your hands to ribbons.
Can't say i've ever seen, heard or worked with AL tape single or multi core cables. I suppose there may well be AL armoured multi core cables around, but i wouldn't say that they are in common usage.
They still make steel tape and steel double tape armoured cables, and you're dead right they were and still are a real cow son to terminate. A good pair of tin snips are an absolute must have when terminating those buggers!! lol!!
View attachment 20806View attachment 20807
In the second picture I have removed the bridge ahead of stripping the sheath back to good ali and re-terminating.
Strange colour coding if you ask me must be foreign.......................
They were our colours!!!!!!!!!!!!!!!!!!!!!!!!!!
Technically, the brown black grey is foreign after we had to comply with europe.
Red, Yellow, Blue.
Brown, Black, Grey.
Hard to see in some light, but let's face it, it's not rocket science is it.
If simple colours are confusing you, then it's back to the classroom time!
