How to wire GENT fire alarm sounder! | on ElectriciansForums
Discuss How to wire GENT fire alarm sounder! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
linuxthefish
Hi, i've aquired a GENT sounder (unsure of model). Where do the wiring connections go for it?
The connections on the back are: 2x -VE, 2x +VE, and 2x REM. What do these mean? :s
assuming it's a 24V sounder, 2 +ve ( in and out ) and 2 -. stick 24V DC across it. + and -
REM is for a remote indicator on detectors. e.g if the detector is in a cupboard or lift shaft. not sure what it's for on a sounder.
Reply to How to wire GENT fire alarm sounder! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
Commonly known as double knock, some pirs have a latch on time delay for a few seconds, giving time for the 2nd one to activate .
