How would you do this .................... | on ElectriciansForums
Discuss How would you do this .................... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Customer is having an extension. In the extension, wet under floor heating to 3 zones is being installed.
The GSR says he wants a plug adjacent to the manifold .......... and he will plug the manifold etc into that.
This means the boiler will have 2 supplies..........
Do you.....
Am I right in saying they will be 3 zone valves for the zones controlled by individual room stats?
I’m a bit lost to the purpose of the socket.
Edit to supply the pump etc on the manifold.
If he insists then you have to provide appropriate warning labels.
Insist it should be supplied from the same circuit.
I would never have two supplies to a heating system but seen it done many times by the wet trade!!!
As far as i would be concerned you need perm L, switched L, N &E which you obviously know. There might be a switchable /triple pole and earth socket out there for them to plug into at a later date :)
All you are doing is outlining the 3rd option on the poll
No I'm not, IMO there should be 4 options. If I was responsible for wiring in the S/L then I would provide a 3core and earth and terminate it into a triple pole isolator at the new manifold position. If I wasn't responsible for providing the SL then I would do as he asks but explain to the plumber/person in charge of the job my reservations.
Reply to How would you do this .................... in the UK Electrical Forum area at ElectriciansForums.net
That's brilliant Dave, thanks again. I had to raid my sons felt tips and pencils for any colours available! Apologies for the strange and...
4K
Thanks for the replies. I’ll see what kit the plumber has & take it from there.
