I can now do a junction "box" mf in 20 secs, switch loop and feed | Page 3 | on ElectriciansForums
Discuss I can now do a junction "box" mf in 20 secs, switch loop and feed in the Electrical Tools and Products area at ElectriciansForums.net
Think a good use of these, if they could take 2.5mm (& 32A), is spurring off a cable on a RFC as a through connection. The instance where you can't use a Wago box, 'cos there is not enough slack on the cable, for the two cut ends to go into the one entry of the Connexbox.
A Hager J803 usually does the trick.
Originally when I wired a switch and loop in loop out in a junction box it was one of those brown bakelite 4 terminal little brass grub screws. In a loft bent down in partial darkness and I had to get it exactly right. You can't imagine how glad I am something like this and the strippers that come with it, and other things like wago came along.
think those brown circular junction boxes have had their day now. they can R.I.P. along with the SR 53, Hindenburg, Steam Power, and the Fairey Swordfish.
Thanks for the user feedback info Vortigern, i did look at these last year at Elex but got put off by price. I can see they will come in handy for certain jobs.
For smaller joints i usually use a little jcn box from toolstation Junction Box IP20 4 Entries - https://www.toolstation.com/shop/Electrical/d190/Junction+Boxes/sd3071/Junction+Box+IP20/p59791 and push fit connectors.
As for very quick downlight install...
Saxby shieldplus MV downlights are good mid range with integral push fit with 2x cable capacity.
[ElectriciansForums.net] I can now do a junction "box" mf in 20 secs, switch loop and feed
if you like the 2 cable push fit entry, have a look at the JCC V50. only 50mm tall, and can be covered by insulation. since finding these, i specify them on all installations.
I got them a month ago from trade fair. The best product at the show.
Brilliant time saving when doing lighting in loft for first floor. I hate being in lofts so anything that hurries the job is brilliant.
Really easy to use.
Thanks for the info...I do like the look of them especially 50mm height is useful and will bare them in mind in future. I am more of a fan of the replaceable lamp option, easier to maintain/upgrade without damaging the ceiling.
No, I can't see a situation where I would need to use them to be honest. Would you be using them?
I’d doubt it tbh. I could see their potential for suspended ceiling lighting. And look much faster than using click flow connectors.
But the wholesalers round here would charge a fortune for them to make them not worthwhile anyways lol
Yes I bought a starter set too at elex show.. they work fine, the strippers alone are worth the money.
They are a real time saver so if you have lots of junctions to do I reckon should be cost effective and they leave a very neat and consistent jacket and wires strip..
I would also endorse the fact if space is an issue they are very compact, apart from the fact that unless you want a simple cable in, cable out you need to use both ends of the splitter; sometimes the job demands access just one end of a jb, like the wagobox.
Well worth trying in my opinion .They definitely have a place..
Reply to I can now do a junction "box" mf in 20 secs, switch loop and feed in the Electrical Tools and Products area at ElectriciansForums.net
