I can't get into some lamp posts | on ElectriciansForums
Discuss I can't get into some lamp posts in the Electrical Tools and Products area at ElectriciansForums.net
H
hillbillie
The usual key I use is:
Switch key - Universal 9 in 1 : C.K Tools
There are 3 triangle keys on this and usually the biggest one works. However, the posts I need to get into now have a triangular bolt, with rounded edges, which is too small for the largest of the triangle keys and too big for the second one down. Any one got any ideas?
I see some manufacturers make a 6mm, 6mm and 10mm triangle keys but I assume these are what the CK multi tool above has, though even the CK website doesn't say.
Help!
I've had this before but now I've got a kry which came with a new post which fits the other size... I'd suggest you google lamppost suppliers and see if they can supply one
Reply to I can't get into some lamp posts in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
By the looks of it the whole head comes off in one unit, guess it has a driver inside of it. Ive tried to Google the Image i have, one comes up...
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
they need to be in a enclosure you can't just put them in ceiling or leave them hanging out
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
96K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
22K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
