G
glbell
Hi,
Is there such a thing as an immersion heater regulator.
I have no electrical experience but here is the question.
Usual topic of diverting PC electricity to hot water.
Instead of changing the 3kw element to a 1kw as most do can you have a regulator (something like a dimmer switch) where you can put the immerser on when you are producing 1kw say WITHOUT then using 2kw off the grid (as would happen) this is acheived through regulating the power to the element - is that possible.
this means when you have 3kw you can use it to quickly heat the water but when you only have 1kw it just takes longer.
At present we are wasting time switching on and off (aint sustainable) so its either a 1kw element or some sort of regulator.
Any thoughts please
Any thoughts please
