Inadequate earth | Page 4 | on ElectriciansForums
Discuss Inadequate earth in the UK Electrical Forum area at ElectriciansForums.net
A
Akanami
Hi all, i'm new here and hopefully you can help.
Ive been asked to look at a DB for a small office area which apparently has an inadequate earth and they won't issue a (COC). I have to carry out a continuity test on the CPC which is fine but what value should I expect to see and if its too high what should I do?
Many thanks
Reply to Inadequate earth in the UK Electrical Forum area at ElectriciansForums.net
Good thinking - the other side of that is my garage and also where the gas comes in so probably quite a tidy solution if it comes to it!
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Recommended Sponsor News
Hi everyone,
