Discuss Increase current amperage by using darlington transistor in the UK Electrical Forum area at ElectriciansForums.net
I'm using DC adapter 5.8 volt with 580 miliamp to produce 1.5 amp by using a pair of NPN transistor 2N3904 to be build as Darlington circuite.
Is it possible?
You could in theory build or buy a buck converter to generate a lower voltage at higher current, but given 580mA at 5.8V (3.3W) available, the max voltage you could get with 1.5A draw would be around 2V,i see, I just to booast the amperage but don't care to lower bujt simply used to charged two 1.3 Li-ion battery
I see, It is Nimh cell with two batteries.You could in theory build or buy a buck converter to generate a lower voltage at higher current, but given 580mA at 5.8V (3.3W) available, the max voltage you could get with 1.5A draw would be around 2V,
I may be missing something, but a Li-Ion cell is normally 3.7V, not 1.3V. NiCd or NiMh batteries are 1.2V.
Where does the 1.3 come from? But you can have 1.3Ah Li-Ion cells!
Reply to Increase current amperage by using darlington transistor in the UK Electrical Forum area at ElectriciansForums.net
