innacessible joints
B
brightspark2010
if a joint is to be made under a floor wich is going to be deemed innaccessible can through crimping with the approriate tool in a cable clamped and mounted chocbox be the method of the join with normal solid core pvc/pvc twin and earth i have heard this is not acceptable any ideas:confused:
All joints must be accessible for inspection
crimp then heat shrink or
ashley do a decent maintenace free 32 amp (rectangular box)
not chock blok n tape!
have to try them. funny how screw terminal junction boxes have been in use for over 100 years and now they are banned ( unless screwed to the surface of the client's expensive decor )
electricalserv - whats the reason your doubtful of these? have you ever had a problem which has been caused by this?
im not nocking you just wondered why your not keen
Never had a problem with them but many a time found faults at joints i.e loose connection at inaccessible joint boxes(more trouble than its worth. I suppose wago's sort this out.
wagos definitely do. better than crimps. you'd break the cable before a wago will let go ( bit like an ex-wife ). after all, through crimps were intended for stranded cable
