Discuss install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
OK THAT FINE I WILL INSTALL A CENTRAL HEATING SYSTEM
THANK YOU ALL
I THINK HE MEANS PLUMBING BARMITZVAS IN PLACE OF THE ELECTRIC SHOWERS AND PLUMBING IN HOT WATER FROM A CENTRAL SOURCE.
OR
HE COULD BE PUTTING A RADIATOR IN EACH SHOWER THAT THE GUSET CAN GUG WHILE GETTING A COLD SHOWER.
"Guset can Gug" WTH does that translate to in English GBDamo?I THINK HE MEANS PLUMBING BARMITZVAS IN PLACE OF THE ELECTRIC SHOWERS AND PLUMBING IN HOT WATER FROM A CENTRAL SOURCE.
OR
Guest can hug, I’d guess @Pete999........been reading buzz posts for to long!
WELL GIVE US SOME ADVICE ON THE EXISTING SUPPLY 3 PHASE/SINGLE PHASE. EXISTING LOAD. EXISTING CUT OUT FUSE. CAN THE EXISTING BE UPGRADED IF NECESSARY?I ASKED FOR ADVICE'S BUT NO ONE IS ABLE TO GIVE ME ONE
I NEED TO KNOW WHAT TO DO SIMPLE IF YOU CAN HELP YOU WELCOME IF NOT THAT FINE
Classic Telit's OK, the hotel is owned by as bloke named Basil, married to Sybil. they have a Spanish waiter called Manual. all OP needs to do is CTFM (consult the f*cking manual).
Who did?He said something about gas ...........
Agree a chancer by any other nameThe OP probably only wants confirmation of what he's already decided. Chances are he's posted the same question on 10 forums and if one comes back with a go that'll be the one he'll accept, ignoring the other 9.
Who did?
THANK YOU ALL
Easy, 500L(ish) tank and a pumped circulation.Sounds more like a B&B if it's only 10 rooms. Chances of the water supply being able to do 10 electric showers are about as slim as the chances of the electrical supply being able to do it.
It might all work fine until the place gets a block booking, with most showers likely to be needed at very similar times
Reply to install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
