install 10 electric shower (8.5kw) in one hotel | Page 3 | on ElectriciansForums
Discuss install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
london
Hi i would like to know if is possible to install 10 electric shower (8.5kw) in one hotel if is possible what changes do I have to make to the general electrical distribution board
Thank you
I THINK HE MEANS PLUMBING BARMITZVAS IN PLACE OF THE ELECTRIC SHOWERS AND PLUMBING IN HOT WATER FROM A CENTRAL SOURCE.
OR
HE COULD BE PUTTING A RADIATOR IN EACH SHOWER THAT THE GUSET CAN GUG WHILE GETTING A COLD SHOWER.
OR
"Guset can Gug" WTH does that translate to in English GBDamo?
Sounds more like a B&B if it's only 10 rooms. Chances of the water supply being able to do 10 electric showers are about as slim as the chances of the electrical supply being able to do it.
It might all work fine until the place gets a block booking, with most showers likely to be needed at very similar times:rolleyes:
The OP probably only wants confirmation of what he's already decided. Chances are he's posted the same question on 10 forums and if one comes back with a go that'll be the one he'll accept, ignoring the other 9.
Agree a chancer by any other name
Easy, 500L(ish) tank and a pumped circulation.
I rejected a large hotel near us who wanted 5 8.7kW showers installed as part of adaptation works. 200A 3P Supply. Would have possibly handled it just about but woukd have been irrisponsible to do it with the existing loading. Already combi showers in so had to reinstall new ones with flow switches for the pumps.
Dont see many hotels with electric showers.
Reply to install 10 electric shower (8.5kw) in one hotel in the UK Electrical Forum area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
Work in a special location needs registration under the requirements of part p in the building regulations. I believe this is a moot point as far...
