Installing earth rod | Page 2 | on ElectriciansForums
Discuss Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
conrad
North wales
Anyone ever installed an earth rod horizontally in a basement?
DB is in basement mounted on a wall that i could drill and hammer rod into "ground".
I agree, a 10mm² rod gets pretty bendy. A 10mm dia rod is much better. ;)
Actually, if you check the research, the rod diameter makes little difference to the Ra. The length is much more important.
The point is the slightly thicker rods have the thread on the end, and it is easy to screw another on to it and go even deeper, these 3 ft things are pretty crap, obviously in good ground they will do the job, I never used them myself, but the ground around here does have a lot of stones in it and they just struggle and are pretty pointless.
Indeed. If you're going to hammer a rod into the ground, you might as well use something you can extend if necessary.
On a serious reply to you, I completely forgot about ENG, anyone here know what has happened to him?
Last time I spoke to him he was in quite bad health.
Have heard unfortunately that he passed away a while ago. Now I don't 100% know this as a fact, as I didn't know him outside of the internet. However the sources I've heard from are pretty reliable.
Reply to Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
