So as long as I comply with the regs I am fine to do the work! The BS numbers is just me being lazy lol But you are correct I am an electrician, my fire alarm experiance is installing from detailed plans, testing and fault finding ! I will have to update and increase my knowledge! Is there a web site that would help with the design I am pretty sure I know what is needed but it would be good to check. Thanks Kelvin
I do't know of any websites really that would help with design - I've attached a Brief Design Guide I did a short while back though - which may help a little.
The real problem is that design varies so much from building to building, it really does have to be done on an each case basis.
There's actually no law, as such, which states that anyone can, or cannot do the work, or that it must be done in a specific way. What the law does ask for though, is a competent design, installed by a competent person, and then commissioned and maintained by a competent person. Invariably, the competence is proven through adherence to the British Standard, and measurement against it.
Suggesting the fire alarms wasn't your main business wasn't a dig in any way - quite the opposite, and many years of knowing where people's skill sets lies, purely from the way they talk about things.
I've said before, and no doubt will again, that the real issues with fire alarm systems are NOT that someone can or cannot install or maintain them - but in making sure the system does the job for which it was designed, to the best possible level. Design, in other words. It's key to any system. And critical.
The reason for this has nothing to do with "my knowledge being better than yours" or ego tripping at all, simply that in most cases, a fire alarm system is installed for life safety purposes - i.e. with the potential to save someone's life. That's distinct from other electrical systems, which invariably are designed to another purpose, with the criteria of doing so in as safe a way as possible, so as not to endanger life. It's a subtle difference, much of the time, but a potentially critical one, nonetheless.
Again, I'd recommend wholly that you do the FIA modules as and when you can - they are worth it - and in the mean time, read what you can on the subject - A book I recommend is (not cheap, but fully worth it) -
The Design, Installation, Commissioning and Maintenance of Fire Detection and Fire Alarm Systems. A Guide to BS 5839-1 by Colin Todd. It's a book that's well worth every penny, and potentially as useful as the Standard itself.
Failing that, generally, if I can help any of the lads here, I will.
Here's the two parts of the design guide I wrote anyway......
(This time actually inserted!!!!!)
View attachment Fire Alarm System Design Overview Part One.pdfView attachment Fire Alarm System Design Overview Part Two.pdf
