Insulation Resistance
, is it best to remove the cables are cu from the bars so you are testing just the lighting circuit required.?
- - - Updated - - -
havent frazzled anything by the way
My God whats next? what qualifications have you got? let us know and we may be able to guide you
Ok, ok, let's start again with a little more honesty shall we?
Hi i`m new poster and not a qualified electrician but I am at college and hope to be one one day. I have got some homework but can't be bothered doing it all myself so I would be grateful if you could give me the answers to the following question:
I have installed an extractor fan with low voltage light in en-suite and now have to do a minor works tests.
I have done the resistance test an my readings are
l/n 0.8
l/e 1.7
n/e 1.3
earth fault loop 6.13
rcd operation 0.2
are these test results acceptable or do i need further testing.
also how do you do a earth continuity test on a low voltage light when it doesnt have one.
thanks in advance.
Don't waste ya time Julian mate. He is having a wind up by claiming he is a spark if he asks if 0.8 L-N test reading needs further testing.
Normally i would help and provide guidance but then he starts with a totally unrelated issue.. Joker!!
i thought i wouldd come here for help but clearly it is not the friendly forum i thought it was
andytucker,
Marvo,
