Interconnection of MV Earth with LV Earth in Public Supply | on ElectriciansForums
Discuss Interconnection of MV Earth with LV Earth in Public Supply in the UK Electrical Forum area at ElectriciansForums.net
Cookie
Earth
What factors determine the interconnection of the MV neutral/earth with the LV neutral at the local substation? When are they connected together and when would it be appropriate not to connect them together?
HV,LV whats MV? thought MV was old hat.
wheres does MV Start and HV kick in? and where does it state the parameters ?
Iec 60071 defines MV as 1kV to 36kV
Most others take the value as 35kV (such as iec60038)
HV is 35kV to 230kV
EHV >230kV
So the usual distribution in the UK is MV (6.6/11/22kV)
Primaries are usually 33kV but could be 66kV, some grid is 66 or 132kV - all HV.
but the bulk transmission is 232kV and 400kV (EHV), although some was 132kV (HV) up to a few years ago - not sure now.
Some transmission towers carried both 132 and 232 in the North West, and some carried 232 and 400kV - for example galloping gertie between Darwin and Bradford.
Edit : apparently gerty is spelt gertie - but neither looks right to me!
Does any one know why the voltage thresholds were chosen?
I'm assuming they are phase-neutral (i.e. earth) since the main risk of shock is touching a line conductor while in contact with the Earth (or attached parts), and I am guessing that the 1kV LV/MV(HV) threshold is related to dry skin breakdown / arc risk where the shock current is much more then 1000/230 sort of scale factor.
But is there some aspect to HV engineering that makes ~35kV a point where different techniques, etc, have to be used to justify the MV/HV category?
At EHV you don't have to worry about touching a live conductor. You would be dead well before you touched anything. NG safety distances are 1.4m at 132kv, 2.4m at 275 and 3.1m at 400kv but in reality it's 'as far away as f'in possible'.
Most power distibution is at 132kv (highest voltage for a DNO), 275kv and 400kv. I've never seen or heard of 232kv.
A reasonably quick way to tell the voltage of a pylon. If it's just got 1 cable per phase it's 132kv. 2 cables is 275kv and 3 or 4 is 400kv.
Interesting stuff,
I thought HV power distribution was delta, so no neutral (star point)
I have no basis for this, other than my own conclusion from looking at 3 wire overhead lines, going to what i presumed were delta to star transformers to step voltage down to 230v (415v) and provide a neutral / earth for consumers??
Reply to Interconnection of MV Earth with LV Earth in Public Supply in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
2 3
