IP 55 Enclosure from screwfix! code 33991 | Page 2 | on ElectriciansForums
Discuss IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just used 11 of these boxes with SWA terminations
They are awful and I dont want someone else to have the same problems I did.
They seem ok, quite sturdy and the price attracts you, however one or two of the screws snapped when doing up the front cover and then MANY more snapped when undoing to test. This leaves a snapped screw in the box which you either have to remove and rebore or provide a new box (both options being a right pain). This happened to 5 of the 11 boxes.
The reason I am writing is because screwfix is the biggest seller to electricians on this site (according to the poll). Screwfix themselves are great, but I would strongly recommend against this product.
IP55 Enclosure Grey 85 x 75 x 65mm | Weatherproof Enclosures | Screwfix.com
TBF HHD the image you posted had knockouts.
Sorry Ferg, when I say knockouts I mean ones you can just give a 'knock' and out they come, BG do these I think. The BG ones (as in the link) you have to drill.
Used a CK pozi size 2 and after one or two snapped I treated them like a beautiful woman and still they snapped!
I'm sure you will tell me off for teaching a granny to suck eggs...
But are you sure you are not cross threading the screws?
Either way lesson learned..
Buy something decent from your local wholesalers that you trust.
Nope, threads wern't crossed. Judging from the other reviewson the screwfix site it seems to be a common fault with them (albeit only 3 reviews). The only reason I ignored the reviews is because I had used a couple in the past without problem.
Fair point I didn't look properly.
I thought they were like the MK weather.... kit.
I'm sure BG do them to where they are more Push outs than knock outs.
Basically an insert with an O ring.
Going back to my previous post, if you are going to go to the effort of using a 20mm holesaw anyway you may as well buy decent and cheap adaptable boxes from your local wholesaler.
i never use a\ holesaw on plastic. takes ages to get the partly melted crud out of the holesaw. use cone cutters every time.
I got a similar set to this for around the same price
[ElectriciansForums.net] IP 55 Enclosure from screwfix! code 33991
Reply to IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
