IP 55 Enclosure from screwfix! code 33991 | Page 3 | on ElectriciansForums
Discuss IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just used 11 of these boxes with SWA terminations
They are awful and I dont want someone else to have the same problems I did.
They seem ok, quite sturdy and the price attracts you, however one or two of the screws snapped when doing up the front cover and then MANY more snapped when undoing to test. This leaves a snapped screw in the box which you either have to remove and rebore or provide a new box (both options being a right pain). This happened to 5 of the 11 boxes.
The reason I am writing is because screwfix is the biggest seller to electricians on this site (according to the poll). Screwfix themselves are great, but I would strongly recommend against this product.
IP55 Enclosure Grey 85 x 75 x 65mm | Weatherproof Enclosures | Screwfix.com
I used it previously in engineering job so took it along in industrial jobs I mostly use it when I use holesaws , which to be honest is usually on plastic as I'll use punches for any glands I put in a metal enclosure as the hole is always perfect with virtually no burrs
what punches are you talking about? do they work in stainless?
"Q max sheet metal punches" is one make can't put up a link or pic sorry but they're on ebay 20mm approx £6
I've got a set 20-22.5-25-30-40-50 mm
I think you could use them on stainless but only thin gauge like on a db otherwise you'd ruin the cutting edges
If you've not seen them before you drill a pilot hole then run a 10mm/13mm drill ,the punches are in two halves, separate them one end has a screw which goes thru the hole screw on the other side and tighten with a hex key/ratchet with hex socket, until it cuts thru and drops out
Its a bit slower but you get a perfect hole and they last for years!
Ps don't forget to remove the slug as my old apprentice did, he complained it was jammed .......never removed the slugs 5 of them
I just said "where did you think the metal from the holes had gone to?"
I just said "where did you think the metal from the hole had gone to?"
ill have a look, we tend to put at least 4 2" bushes between our headers and the panel
on the brittle boxes ill always use a clean holesaw, there too easy to shatter otherwise
[ElectriciansForums.net] IP 55 Enclosure from screwfix! code 33991
I love them they are slower to use but you get a perfect hole everytime, also if the pilot hole is slightly off you can run a bigger drill thru and move the punch where you want it
Reply to IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
