IP 55 Enclosure from screwfix! code 33991 | Page 4 | on ElectriciansForums
Discuss IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just used 11 of these boxes with SWA terminations
They are awful and I dont want someone else to have the same problems I did.
They seem ok, quite sturdy and the price attracts you, however one or two of the screws snapped when doing up the front cover and then MANY more snapped when undoing to test. This leaves a snapped screw in the box which you either have to remove and rebore or provide a new box (both options being a right pain). This happened to 5 of the 11 boxes.
The reason I am writing is because screwfix is the biggest seller to electricians on this site (according to the poll). Screwfix themselves are great, but I would strongly recommend against this product.
IP55 Enclosure Grey 85 x 75 x 65mm | Weatherproof Enclosures | Screwfix.com
If you have to line something like trunking or a sub board up just drill the small pilot butt up the two items and mark ,drill , punch and it'll be spot on for bushes etc
Yeah you'll still have some from the pilot drills but nowhere near as much mess as with a holesaw
You can get a hydraulic tool to drive punches,I'm guessing a different type of punch possibly, panel builders sometimes have them, but I've never used one
Reply to IP 55 Enclosure from screwfix! code 33991 in the UK Electrical Forum area at ElectriciansForums.net
