IR Test ? Weird issue N-E only | Page 3 | on ElectriciansForums
Discuss IR Test ? Weird issue N-E only in the UK Electrical Forum area at ElectriciansForums.net
Soulsurfer
Channel Islands
Hey all, just doing some tests on a small extension and have a weird issue with IR on lighting circuit, all switches left open as nightmare to strip all lamps, fittings etc.. L&N to CPC not ramping up over 7-15V DC then resetting test !
L-N on 250V or 500V 31-32 Meg
L-E 32.6 Meg
N-E won't go ! Tried all obvious things to remove out of circuit plus new mains smoke detector etc.. but still no good, any ideas ?
Only fed at moment on a B MCB 6A no RCBO etc.. head scratching or feeding something hidden maybe or a fault ?
Thanks.
Bit of a hitler the wife
not another one!
Tried again today, still at job now searching for any issues ! 32 Meg L-N & L-E but N-E won't test nor will L+N -E with switches closed, open, ufh Rcd spur found and isolated, lamps out & in, dimmers swapped for standard switches, main switch off at cu and only L&N out N bar /
mcb ! Anyone seen this before ? Fault somewhere ? I'm cracking up here
Ditch your multi function tester and get yourself a proper dedicated insulation resistance tester:)
I prefer that its me who decides when a test can proceed, not some all singing and dancing modern playtool that is all things to all situations
Just ditched my Fluke and bought a shiny new Megger 1731 on NIC assessors advice ! So would it be likely a stand alone IR tester would do something? As I ditched my seperates for the Fluke !
Sounds like fun.
How many separate circuits are you talking about?
So, just break the circuit into sections and home in on the fault.
DO NOT fault find using global IR ............ it won't work ( well it might eventually) but its not the way to approach this...
You need patience, a note book and a pen ............. then test each circuit (cpc's connected to CU) one by one then it will be easy............................ and if you find yourself going round in circles, then walk away and go back afresh another day.
To be fair I wanted one since company I worked for had 1553 years ago and it was fantastic and this one is a work of art and technologically another universe but this blinking job is driving me bonkers cause it won't let me get a reading L&N to earth or N-E as is refusing to allow 500V or even 100 V test ! Can't see any reason why
Reply to IR Test ? Weird issue N-E only in the UK Electrical Forum area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
That would depend on the instrument. On my old BM10 when you press & hold the button it just powers up the inverter circuits to generate the...
