I've seldom wanted to tell a customer where to go but just got back from doing a quote in Bredbury, Stockport where I very nearly did!
The customer was after 3 quotes for a rewire after his consumer unit "blew up" and was replaced by an "NIC" electrician who told him he needed a new rewire and rodents may have chewed through cables.
However the customer didn't want me to look at anything - even how to access under the floor which was laminate, or the new consumer unit. I had a look at the ccu none the less and found it had been replaced with a clapped out plastic one with both cover latches broken and different manufacturers components being used. No certificate had been given (and guessing no testing done or building control notification). The cabling, which was a mix of black/red & brown/blue and all looked ok/no thermal damage evident.
I told him the replacement was substandard and he may not even need a rewire but rather an EICR would be more appropriate. The chances are the main switch had burnt out due to bad connections and wanted replacing. Afterall if there was a cable fault then the fault would still be there and tripping the protective device as whoever replaced the unit evidentially didn't look for a fault in the rest of the installation.
Alas, the customer wasn't at all interested in the fact he had a substandard illegitimate board replacement and that he could save thousands just by having a survey done. In fact he was more angry that I had taken the cover off the CCU and was having difficulty getting it to stay on again!
As he just wanted a figure for the rewire without me looking round, and not interested that he may not even need one, I came to the conclusion he had already decided on this "reputable" installer was going to do his rewire and he was just going through the motions of being 'sensible' by getting 3 quotes. So I just drew a number out of the sky and walked out of there with no intention of returning having wasted an hour and petrol.
If the installer of this replacement CCU reads this I'd be interested to know your explanation for installing a broken, plastic, mismatched ccu without paperwork/testing and telling the customer he needed a rewire (when I suspect he doesn't)??
Also, Can someone set up a database of customers to avoid pleeeeeease!
