Is LSF spec or regs? | Page 2 | on ElectriciansForums
Discuss Is LSF spec or regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
[ElectriciansForums.net] Is LSF spec or regs?
422.3.201. Another reg that mentions low smoke.
And what was the bespoke stripping tool? I'm intrigued. Lsf isn't too hard to strip that someone had to invent a took specifically for it surely o_O
Can't remember the make, contractor got it from his wholesaler. Nothing special, removed the outer sheath, then second operation removed the inner insulation.
LSF is a tw4t to strip using the sidecutters pulling the cpc out method.. my preference is a stanley knife to score down the sheath first.
I was stripping LSF a couple of years ago in winter, which was so bad, all I had was two white conductors and a CPC. The stuff should be banned under nuclear treaties
Reply to Is LSF spec or regs? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Who knows? There's this, in the OSG app H: "Permanently connected equipment should be locally protected by a fuse complying with BS 1362 of...
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
