is rcd protection reqiured? | on ElectriciansForums
Discuss is rcd protection reqiured? in the UK Electrical Forum area at ElectriciansForums.net
A
ample current
I have installed a pull cord hunidistat fan in a bathroom. The property has no rcd protection, do I now need to install an rcbo?
In the same house I have installed a similar fan in the kitchen powered from an existing unused sfcu do I also need to add an rcd to this circuit?
Thanks in advance
It doesn't matter what you have installed.
Any new fixed cabling installed in a method that requires RCD protection should have RCD protection.
- - - Updated - - -
In a word, yes, anything you add needs rcd protection! Might be worth checking if bonding conductors are correct size or present at all, I am of course assuming ( against the advice of my great great great great grandfather) that property has a db which was installed when 6mm was ok to use for bonds!
Thanks in advance
This is notifiable work and as such you need to be a member of a scheme, and you should know the answer to this
I'm driving along in my van and there are some Red Amber and Green light in front, the question is do I stop?
Worrying that the O.P HAS installed a fan and is now asking if RCD is required.
Since I decided that anytime I add anything to any install needs rcd protection! In my eyes looking through the regs to see if you have to rcd protect is cutting a corner, why not price it into the job, I get an rcd spur from my wholesaler for 8 quid and it's easy to pop it alongside db and take a feed and the lighting load into!I always price for rcd protection, then if the customer wants it done cheaper let someone else do it, you can't buy a clear conscience!!and if anything went wrong in the future and Mr N.I.C or whoever got wind, I couldnt stand there and say "it didnt need rcd protection"! I'd be ashamed to say that for the sake of a few quid!!
But that's not what you said. The fact is that RCD protection is not always required. However, I do totally agree with everything you said above, I see no reason to look for reasons NOT to provide RCD protection!
Reply to is rcd protection reqiured? in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
