Is this JB adequate for the design and use.
I found this JB in the loft, the mice have eaten the JB cover as well as some of the wiring, but aside all that in your opinion do you think the JB is overloaded?
Should I take out the RCBO's and replace with re-wirable fuse's. 😜
The comment was referring to someone's suggestion of replacing the OP's existing JB with a J601 screw terminal one rather than a wago type. He wasn't referring to the original junction box.
I can't think why someone would use a screw terminal JB these days, when it's far quicker to wago type and make it maintenance free, whether needed to be or not.
Whats wrong with screw terminals, they have been around for decades.
Just for info I was altering some wiring last year for a friend, wagos in the back of a switch for the N not much slack so instead of cutting the wago off (push in type) I pulled the conductor out and it didnt take much to pull out, just thought id share that.
And MCB and main switch terminals also are screw type.
I've nothing against them, it's more to do with ease and also being maintenance free.
Why would you cut it off when you can just remove the conductors from it?
A pull with a bit of a twist is the method for removing the conductors.
What are you actually trying to get at here?
