Is this possible? | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss Is this possible? in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Just said to someone on the phone, yeah I can do that for you, 10 min job, no problem then just gave it an ounce of thought and realized I probably cant.
Heres the situation,
Standard pull cord switch on ceiling, wants it swapping for a PIR.
Can I do it without doing anything to the wiring?, probably not im guessing... I need a neutral done i...
[ElectriciansForums.net] Is this possible?
Or can I run both wires from the switch into the line and neutral at the bottom and bridge across, or will that not work?
Remote-controlled bulbs* and bulb* holders exist, are they any good, how long will the device or the remote survive in a bathroom, no idea.
(*that's lamp spelt B-U-L-B if the term offends you :) )
<edit> Also do ones suitable for bathroom use exist, no idea.
Taking the switch outside the bathroom is not an addition within the bathroom and such an addition would not IMHO impair the safety of the existing installation (MWC form wording).
5 Amp Pull Cord Switch - Contactum
"Quieter action than most ceiling swithches"
Go home TLC, you're drunk.
The bloke doesn't want a pull cord at all, that's the issue.
? Seems like a perfectly reasonable and logical thing to ask for in the situation.
You will come across issues like this more and more every-time the regs change!
It gets a bit embarrassing sometimes when you go back to a house you re-wired less than 12 months previous to do some extra jobs and have to explain that the CU you installed no longer complies!
But it would still be fit for continued service so no problem.
What would that achieve, apart from making you look guilty of something?
I've posted the answer to this one earlier in the thread.
You use your skill, knowledge and experience to assess whether it is acceptable to make a deviation from the regulations or not. Nobody can do that for you as nobody else has seen the existing installation.
If the installation is in good condition, safe and properly installed and your alterations will leave the installation in an as-safe or safer condition than when you started then crack-on.
They've even provided a handy box on certificates to record deviations and reasons for them!
Because there is no logical need for a PIR. They are used in non domestic settings to save energy when rooms are unoccupied as people don't turn lights off. But in a domestic setting the occupants of the house will switch lights as necessary.
There is more to go wrong in a pir than a normal switch.
Changing the lamp will require the whole cct to be switched off on a PIR whereas with a switch you just switch it off, allowing light from the hallway to help you see what you are doing.
If you want the light on when the light sensor in the pir says its light enough you're buggered (I have switch the light on during the day to shave as the position of the window puts half my face in to shade)
Uksparks, why do you reason that moving to a wall switch outside the bathroom (cable surface mounted) is a worry from an RCD point of view but putting a PIR on the circuit isn't?
All reasonable considerations, but if a PIR suits the customer (which it may do in this particular case) and is not unsafe, then I wouldn't refuse to fit one.
Reply to Is this possible? in the UK Electrical Forum area at ElectriciansForums.net
Been quoted £120 +materials To sort wiring and wire to extractor fan What do you all think on that price ? The electrician lives 1/2 mile away
Recommended Sponsor News
Hi everyone,
