Ive broken the front cover to the consumer unit | Page 7 | on ElectriciansForums
Discuss Ive broken the front cover to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
L
lofts
HI guys
Ive accidently broken the consumer unit in the empty property im working in at the moment. I took the cover off of the Memra 2000 Ad board having isolated all the breakers, rcd's and main switch then I took the main fuse out (yes Ive taken the main fuse out before with out doing so and it was just a little bit scary with all the sparks and crackling noises)
Being a bit heavy handed and just rushing I guess Ive gone and broken the front cover so that it wont screw up tight at all.
I cant say that taping it on would be a good look, and I cant see that being acceptable at all. I also wouldnt want to do that but My dilema is this. I not sure the company has plans to do a board change even tho I have added a new kitchen ring to the old board board. additional sockets on both the up and down stairs RFS's etc. I have adivised that they have a board change to bring it up to current regs (17th eddition board) as I have made alterations and additions that need to comply with BS7671. Ive been told there going to look into it, but if it is allowed I guess they will just try and put the new kitchen ring on a rcbo and the existing up and downstairs rings both with additional sockets added to them on a rcbo as well as this will comply and allow them to keep costs down.
cheers
What can I do if they go for this option as I cant leave this cover like it is, its just waiting to fall of exposing all the live parts etc, also the earth bar inside this cosumer unit is a bit loose imo.
Whether he's trolling or not...
There are employers out there taking terminal numpties like this on, pay them shag all.
This country is fooked, no one gives a ...
I'm at the point now, that I really don't give shït anymore.
how do I know wether to use the 1mm or 1.5mm i usually go for the 1.5mm so im covered but I wouldnt mind knowing when I can get away with 1ml and when I cant
i believe you can get away with 1ml and still be under the drink drive limit
you aint done 2330. maybe leve one but you have to do cable calc in lvl2/3
obviously you havent done this so should not be touching electrics as you are currently dangerous and know less than the average diyer
Reply to Ive broken the front cover to the consumer unit in the UK Electrical Forum area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
