Kitchen Appliance circuit | on ElectriciansForums
Discuss Kitchen Appliance circuit in the UK Electrical Forum area at ElectriciansForums.net
Snapester
Designing a kitchen appliance circuit, i plan to feed a bank of grid switches with a 6mm T&E fed via a 32A MCB, then each switch will have a 2.5mm cable to a fcu supplying an under counter appliance.
My main question is, is it ok to change down to 2.5mm and then feeding the FCU? As the cable cannot be overloaded as the main load is connected to the FCU at position?
Regards
come on I=P/U....you gonna try stuffin 4mm or 6mm into the back of an FCU?...lol...
i read it as 6mm to switch bank, then 2.5mm to each FCU. but doubt if could link switches in 6mm
telectrix yes that is a valid point! Maybe i will run a 4mm 20amp radial i will check the calcs!
I should have thought about that one damn! This is why you guys are good to run it through with!
Reply to Kitchen Appliance circuit in the UK Electrical Forum area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
