Kitchen wiring | Page 4 | on ElectriciansForums
Discuss Kitchen wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
all good and well, but why would you want to cut off the factory sealed plug off an appliance and waste time wiring it in ?
so much quicker to plug in the appliance !
and most manufacturers state you cant remove the factory sealed plug otherwise the warranty is invalid !
No they don't, and No it doesn't!!
you need one of these,
[ElectriciansForums.net] Kitchen wiring
and 1 of these
sod the switches.
I have my own way of dealing with the double fused built-in kitchen appliance phenomenon!! Here, in the staff dorm' kitchens, built-in appliances will be fed via local SCHUKO type outlets from DP FCU above worktops. (i never have and never will mount outlets in kitchen cabinets) In the UK if you want to keep everything to BS, then you can use 5A/15A outlets.... Problem solved!! lol!!
Personal choice I guess lol
I'd rather be another roll of cable better off lol
The difference between a ring a radial is a length of cable from the last socket to the CU, unless this dudes kitchen spans a distance greater that 40-50 meters, i think your roll of cable is safe..... you must be welsh. Tight git ;)
Reply to Kitchen wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
