Lack of RCD protection on Sockets a C2? | on ElectriciansForums
Discuss Lack of RCD protection on Sockets a C2? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sl1210
I received a EICR from a customer from an NICEIC member who had deemed the installation unsatisfactory due to there being no rcd protection to sockets and the heaters (C2). So I am going to change the consumer unit as that is what she wants done.
Now I personally would class that as a C3 if there was supplementary bonding.
Surely half the houses would fail in London due to lack of rcd protection?
I havent been to the job, but I wouldn't of thought so. Anyway he gave economy 7 heaters on the second consumer unit a c2 too.
As 'Alan' states should only be a C2 if there is a possibility of feeding outdoor equipment. For most houses this would be correct unless its a London flat above ground level where my view would be C3!
Yes sockets that could be used to supply portable equipment outside C2, all other sockets C3 and only a C3 for heater if cables are buried in wall otherwise no code. But changing the consumer unit for dual RCD will correct all the above
Suggest a good read of the regs in order. The regs are not RETROSPECTIVE, earlier editions of the regs WERE NOT DANGEROUS, so if an installation is to an earlier edition of the regs, and it has no defects IT IS STILL SAFE. You can recommend an installation to upgraded to current standards. No RCD's IS NOT DANGEROUS, it is RECOMMENDED to have them but not compulsory. C3 IMPROVEMENT RECOMMENDED, NOT C2 it is not dangerous.
Cheers...........Howard
I've always been guided by NICIEC that any socket than can be used outdoors is A C2 if no RCD fitted . But do agree with Howard that you are testing to the regs when the installation was installed, I personally started on the first Red 16th addition where RCDs for sockets liable to be used outside have to be RCD protected, I don't have a 15th addition book but I'm guessing RCDS did not feature in it :)
Having a field day on RCDs today! Another interesting point around interpretation of regs and guidance from 'governing' bodies.
Regs 411.3.3 (only quoting because i was told this pulls the chicks!) states RCD required for sockets likely to provide outside equipment. Obviously no mention of what code it is in the regs.
Electrical Safety Council publication on codes recommends code C2 for sockets providing outside equipment without RCD which most domestic premises will fall foul of.
I know its all recommendations but if the proverbial sh*t hits the fan and one hasnt followed the recommendation of the ESC in giving a C2 where does that leave you?
Discussions please ........
agree if before 16 th eddition, and most properties are then c3 or nothing recomend updating but not an issue.
how many times have i been told by customer that they have been told they need a rcd usualy by a plumber or british gas.
i could make a fortune if i didn't tell them the truth.
I know its late on a Saturday night but thats the dichotomy I have. When completing an EICR you have to do it against the current regulations and not what was the regulations were at the time -- be it safe then or otherwise.
Being very general, domestic properties fall foul of having sockets that are liable to provide outside power and in-line with recommendations from the ESC you have to call it a C2 which records the EICR as "Unsatisfactory".
If you dont follow the ESC recommendations then what arguement do you need to present that you know better than the electrical lord & masters? I wouldnt want to be trying to prove that in a court of law but would be interested in knowing otherwise. Hence the discussion bit ........
Time out. All that is required by regs is simply. Is it safe for continude service acording to regs circuit designed to.
Otherwise every single building over 3 years might need updating because of the amendment
Reply to Lack of RCD protection on Sockets a C2? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Usually if there are only C3 observations it would usually be deemed satisfactory but could be found to be unsatisfactory in unusual...
davesparks
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
