laser level | Page 2 | on ElectriciansForums
Discuss laser level in the Australia area at ElectriciansForums.net
B
brizospark
I have been assigned to a job where I have to install a lot of containment down straight corridors, some of which are around 30m long so I have decided that now is the time to invest in a laser level
Basically what I am looking for is a laser level which can sit on a tripod and project a line down the ceiling. There are steel beams across the ceiling at 4m intervals so my thinking is to sit the laser on a tripod and project up to the ceiling at an angle
I would like a laser to project at least 30m
Any suggestions for a price limit around ÂŁ150?
Watched a chap use a rotating laser marker once to fit a false ceiling....what a piece of kit mustve saved hours faffing about (with chalk !!!!) Saying that i am still a spirut level and chalk man. Christmas soon.
lining up holes in joists! i guess your not working on a price! i think holes in joists by eye is quite acceptable. but i do use the dewalt laser level and it is very good, especially for kitchens when they are being tiled because sockets that arent level with the tiles do look mmmmmmmmmmmmmm nice. and yes i have used it for lining up fittings down long corridors in a sports centre and it works fine.
A chalk line is the way forward IMO. You'll have to measure and mark out couple of points to make sure the laser is running through them both so you might as well just ping a line between the marks! then no one can knock your tripod just as you finished setting out!
Reply to laser level in the Australia area at ElectriciansForums.net
yeah, think this will be the best way around it for me, thanks, having thought about it, if the country is as short of sparkys as peope make it...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
