LED Bulbs won't work together on same circuit. | Page 3 | on ElectriciansForums
Discuss LED Bulbs won't work together on same circuit. in the Lighting Forum area at ElectriciansForums.net
Thank for the update. Whoever suggested the loose neutral gets first prize :D
Not to blame Andy! Not sure what you mean by switch wire rather than neutral. Both the roses and the switch only had a single red (live) and black (neutral) plus earth, which is not like any other circuit in the house. So how the rest of the circuit is wired I do not know. It was put in about 30odd years ago and I was working in those days so didn't see it installed.
If you only have 2 cores at the switch, one must be live and the other must be a switch wire, very often in a 3 plate lighting circuit (see pic), a twin and earth cable run to the switch is used like this with the red core being the live feed to the switch and black core used as the switch wire. If you have the same at the ceiling rose and the red has become the switch wire and the black is the neutral... It looks like there may be junction boxes somewhere...
Thanks Andy - there could well be junction boxes elsewhere. Like I say I didn't see any of it go in. Furthermore the builder went bust in the middle of the job, which meant that a number of things were not as expected!
Reply to LED Bulbs won't work together on same circuit. in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Sadly not very near Swindon! I'm in Oswestry. Thanks a lot for the thought though!
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
