Lifting carpets | Page 2 | on ElectriciansForums
Discuss Lifting carpets in the Electrical Tools and Products area at ElectriciansForums.net
This does it for me: Screwfix £6.95
Well done 'confused-fuse' well traced, those are the two types i've used, the slide hammer type is a bit weighty but works well if you have a lot to do, and the mini one is great as a tool-box special. I'm afraid I wouldn't want anyone lifting the oak boards in my house with a 'screw-driver or crowbar'....... that sounds very pikey and unprofessional :eek::D:eek:
Just as well the OP was asking about lifting carpets and not oak boards then.
What you should do is tell the client before you start that they would need somebody to re lay the carpets "properly" once you've finished...
No problem with taking it up.... good old long nose pliers
It's getting it back down, dending on the orginal state of carpet I have used this one a few times before....
Long nose plyers and hands to get it up from the corners. to get it back down smooth it out with my hands, then use my bolster to get it over the gripper rod. it seems to pull it all tight. Along the door strips i use my stanley knife backwards.
Paul
I hope you all know how to use the carpet kicker as the teeth are adjustable and if they aren't set deep enough you'll tear a great chunk out of the face of the carpet.............:eek:
Be careful out there guys:D
our company has a disclaimer in the quotes about carpets something like 'while our engineers have expierence lifting and re fitting carpets we can not guarantee refiting to the quality of a professional carpet fitter' we recommend the use of a professional carpet fitter to check the quality of the refitted carpet if you have any concerns',no doubt gets them out of any claims!!
Please never throw anything made by bahco (apart from their files mede in Portugal) I've always found them to be very well made and designed tools. They invented the adjustable spanner and because they didn't patent the direction of the tightener everyone else has them. Top engineering.
Is that right? Nice. I like Bahco because for some reason whenever I see their logo I think of some kind of surf-wear company. 'Bahco wetsuits - narlyer than narly'.
Just brought one of these from Argos.... hopefully will stop my mate moaning now:D
Will let you know how we get on will be using it on Tueday, looks a bit of a beast.... might give it a go a at home first so we dont have any cock up's:eek:
Agree Bahco are top tools, but what's wrong with the files, I've had no probs!
i just get my snips in the corner of the shag and pull the corner up , never apply to much force or you WILL damage the carpet, but if your carfull its a good method
Reply to Lifting carpets in the Electrical Tools and Products area at ElectriciansForums.net
I disagree. IF you have a use for it, it's just the tool you use. And when you do have a use, it'll be one of those "wish I'd bought it years ago"...
N
Help Needed: Fixing My Damaged Tub with Devcon Metal Patch & Fill Hey everyone, I have a pretty messed up tub that I need to fix, and I'm hoping...
NETSURFER802
N
