Lifting floorboards for socket
Hey guys.
I know how to spur a socket etc. However never done one in a house.
I want to put a new socket in my room.
How do I go about lifting the floor boards etc? Would I just pick 1 or 2 and feed the wires through? But I may need to make the holes in all the joists ?
Any help would be appreciated.
You may need to lift a couple of boards up to see what the best route is.
Don’t forget to consider any room the other side of the wall. Sometimes it is easier to go through the wall to the other side, especially if you end up in a garage or a cupboard etc.
Thank you so much. So it all depends where its spring from.
It might even be case of taking all the floor boards if rhe socket is the opposite side of the room? And unable to find anything on the otherside
It might even be case of taking all the floor boards if rhe socket is the opposite side of the room? And unable to find anything on the otherside.
which room ,you could ring Mr superman he could tell you with xray eyes.
look for the nearest socket and work from there ,most rooms either have one or two ,some times the hallway .
No.
Your floor boards run perpendicular to the joists. That means you can run across the joists with just one board up (note the comment above about where you can drill), or along the joists with one board up at each side of the room and fishing along the space between the joists. Usually it's a combination of both ways.
As to getting a board up, what type of boards do you have, and how are they fixed ?
