Lighting circuit what to do | Page 4 | on ElectriciansForums
Discuss Lighting circuit what to do in the UK Electrical Forum area at ElectriciansForums.net
SW. London
This is a new one on me and not so sure how to tackle it. The customer is extending 3 bedrooms, ive quoted to install new lighting circuit for these rooms.
The existing circuit for the upstairs lighting does not have an earth and due to its routing it will need extending to fit round the shape of the new rooms. This existing circuit is supplying j.b's in the loft that spider to the bathroom, hall, and another bedroom; the customer will not agree to have these rooms rewired in t&e as it means making holes in the ceilings ! (----)
If I bring in a new feed to the existing J'bs how do I stand on reconnecting the existing circuits that dont have a cpc ?? Customer is adamant he dont want existing rewired but he wants the lights back on, I will IR each of these existing lighting circuits, if they pass I was thinking to make a note on the EIC that customer refuses rewire, and then reconnect.
What’s wrong with a socket over a draining board :)
Actually as I recall, as long as it’s 300mm from the sink edge, it’s fine apparently.
When I did small jobs, most of mine were, I did the install to the latest regs. Much as I would like them to have a rewire or CU replacement, that’s down to the customers decision.
The 300 mm is guidance only. I do stick to the 300mm but in a small kitchen where space is not good, if I have to, I alter the distance to 150 mm.
Agree CU change is down to the customer, but if adding to a socket or lighting circuit the customer must have the RCDprotection as is required by whatever means, otherwise I cannot do the job.
[automerge]1568881346[/automerge]
Yes you’re wording is far better than mine. I’m useless on here with my way of explaining things. All that you’re saying here is exactly what I say to my customers which in simple terms your electrical installation is not up to current standards I recommend you bring them up to standard. I don’t just mean with old rewireable fuse boards but the whole electrics in the property I’ll look at everything and don’t like to leave without telling them what is not compliant with current regs regardless of I’m working on that particular circuit things like cooker points over the cooker or socket outlets over draining board. Knowing that I’m the last electrician in that property I like to make sure that I explain all the issues there
I totally get you with regard to wording.
It’s taken along time for me to get it right. Literally decades.
I’m naturally brilliant at maths , gut absolutely rubbish in my English skills.
Bullet points.
Spaces.
Paragraphs.
That’s how I can get what I mean to say on paper.
Also when I started writing quotes I had to get it right out of nessecity. I would get my wife to check them all. Practice made me able to do this.
I had a 3 hour written exam couple of years ago. I was bricking it. I did the above and passed . Bering in mind it has a 60% fail rate.
I was prouder with myself for actually being able to write what I meant than the content.
I always know the answers but finger it difficult to write it.
I should add, that the guidance now is 300mm from the sink ‘bowl’, not the edge of the drainer bit, like I used to think.
Apparently its in the 2019 NHBC guidance, and blue OSG, neither of which I have access to.
send me your bank details and PIN and I'll nick those books for you.
Bullet points.
Spaces.
Paragraphs.
Haha yes I’m the same, I’ve always had a natural ability at maths but English shocking! My wife also tried/tries to educate me but I just can’t get it to sink in. Fair play to you passing the written exam that’s a big ask for people who struggle with English.
Back to electrics I was under the impression it had to be 300mm from draining board and the 150mm applied to the edge of cooker (scorch zone)?
The 300mm is not actually in bs7671. So is not a reg.
It is guidance only. Yes it’s good guidance and you need a very good reason not to apply it.
Sometimes common sense is what is required.
Right ok I’ll bear that in mind but yea like you said common sense is required and I’m over cautious so certainly won’t be putting socket anywhere near water source
I’ve just kind of come across the same. No CPC on lighting circuit, so advised customer that they are to only use class II fittings and plastic accessories. Also put label on DB indicating said circuit. Advised them of getting either a earth feed in from DB or get a re-wire. They’re not too keen on those options. So put a note on the MWC.
Reply to Lighting circuit what to do in the UK Electrical Forum area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
