Lights not working
Dec13
I was called to a job in a new apartment block this evening and the lights in the apartment were out. All MCBs for the lights on the consumer unit were up, and reading 230 volt but when I put my meters on all of the lights, I had no volt reading. Any ideas on where the fault is????
Dec
ya doesnt sound like broken neutrals across both circuits.....Am calling back tomorrow and will check if there is an emergency light test switch....Thanks for that, good idea Ian.....
