Day 89
Set 42005, monster truck.
Small set, with big pieces. Handy just for spare parts. Front and rear suspension and 4 wheel steering.
Front and rear are identical builds.
Day 90. (Do I have another 10?….. oh yes)
Set 42028. The big bulldozers little brother (day 69, message 103)
No motors, but shovel and rakes both lift. Tracks turn the pistons when moved.
Day 92
Set 42024 Skip lorry
Motorised. Function through gearbox is with lift off skip container with stabilisers down, or tipping container with stabilisers up.
Day 92 1/2
Back in July, I posted the Fast and Furious Dom’s Charger set… day 39 I think.
last week, I pulled it down and built another classic vehicle from tv/films (instructions sourced online)
not keen on the engine sticking up, but there’s not enough parts left over to cover the hole.
Day 93
Set 42022 hot rod
just a little one here. Steering, moving pistons and easy system to make it a convertible.
Day 94
Set 42038, artic tracked vehicle.
got a spare one of these, so built the second model as well.
Both have steering, and a winch. Main model has tipping bed, and is motorised for just the tipper, and lifting the crane. Winch and rotation of crane is still manual.
Say 95
Set 42032. Compact tracked loader. “Bobcat” type
gear on rear lifts arms. Levers either side tip bucket or close the forks over the bucket.
Day 98
Set 42050 Drag racer
Strange design, but plenty of functions and big, big wheels!
Steering, lifting cabin. Moving pistons.
Rear frame holds battery box when using electric motor. Extra weight makes it wheelie when going forward.
Also has a wheelie frame underneath that can be moved down.
Day 99
Set 42049, mining loader
I’m sure this is based on a real vehicle…
Steering, pistons and lever to lift the grabs at the front.
tomorrow is going to be big.
DAY ?
This is it… the big one. Or it was at the time. There have been bigger since, but in 2016, this was the biggest at 3929 pieces
Set 42055. Bucket Wheel Excavator.
Battery with only one motor, uses 3 sliding gears to control main vehicle movement, rotation of the superstructure and the digging bucket and conveyors.
Emmet minifigure added for scale
Day 101.
From the biggest to one of the smallest. Hardly technical at all. Gear wheel on side lifts the wheels. That’s it.
Set 42044
littlespark
Staff member
Supporter
Patron
Scottish Borders
Littlespark’s collection
Electrician Talk Forum
Thread Tags
Tags Tags
collection
littlespark,
littlespark,
TrueNAS JBOD Storage Server
