Live wire taped off in the loft. | on ElectriciansForums
Discuss Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
Goatus
Glos
Afternoon all, new on here and hoping someone maybe able to offer a bit of advice?
I am flooring the loft at the moment in the loft, and there is a length of wire (grey 3 core) that has just been taped off and taped to the rafters. The wire is live (240v) but isolating the MCB for upstairs lights/sockets and downstairs lights sockets makes no difference so assuming it's not to do with them! I did wonder whether it was put up to faciliate loft lighting?
As mentioned it's a fairly new build house.
I'm a novice at this and am curious as to what it was and if anybody would know?
Many thanks
Nick
loftlight or maybe an aerial amp.youneed to find which MCB isolates it, then trace it back.
How do you know it is live?
wet finger test???
There seems to be a lot of tape around.
First question. How do you know the cable is live?
edit….late, it seems.
Cheers for the quick replys!
Firstly im assuming as testing with a voltage tester / multi meter is bringing a reading of 237/240, although wet finger test would give a positive result I'm sure! :astonished::astonished::tearsofjoy:
There are Ariel wires up there (as in the previous house) so thats another option! I shall continue the search!
It comes up on the exterior wall side, which is also the side of the consumer unit (located down stairs in the under stairs cupboard ). Yes that's right L N and earth. I've attached an image of said wire, not that it will be much help!
Thanks again!
[ElectriciansForums.net] Live wire taped off in the loft.
who the hell puts washing powder in the loft, unless it's a funny place to get 'er indoors out the way, doing the weekly wash. :eek::eek::eek:
oops, just seen it's a recent build.navigation through the jungle of weedy roof trusses and 2 ft/ thick itchy-poo needs a risk assessment, full bio-hazard suit, and a link to the local plod's missing persons department.
Thanks again!
Looks like it's 2.5mm2 that has been spurred from a socket in one of the bedrooms.
Try isolating the sockets upstairs, or is there a spare way in your fuse board marked up as loft supply or something that may look like it, probably a supply for a roof socket, get an Electrician in to identify and terminate it safely, left like that is dangerous. Simple 15 min job
Reply to Live wire taped off in the loft. in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Part III:). I think I have clarity-having spoken to my electrician who installed my heaters, he said that the part of my fuseboard that is...
2 3 4
