A customer previously (earlier this year) had a new 65m length of 10mm SWA installed but not connected – from a utility room housing the CU, to the far end of the garden, intended to power lights and sockets in a shed, done at the same time as an extension to the house.
Testing the SWA, sadly it is damaged. There is a reliable / stable short between Brown & Black, measures 0.03 Ohm from the CU end, 0.21 Ohm from the shed end. This puts the short at approx. 8m from the origin of the cable by the CU, but the trouble is with such low value readings using a KT64 MFT is I don’t know how accurate they are. The 8m point is approx. where the cable exits the recently built extension - it is concreted into the extension floor, then exits via the wall to the patio.
There is also a less reliable short between these cores and the sheath – it varies but typically under 1 Ohm – and so not very helpful in locating the fault. I’m guessing it is could be something like a screw or nail into the cable and firmly resting against the two cores, and just touching the sheath?
My question: is there any easy way to determine the position of the fault more accurately?
