Loft conversion - RCD main switch query | Page 2 | on ElectriciansForums
Discuss Loft conversion - RCD main switch query in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Unsure where to post this so if this is in wrong section I apologise!
I have been asked to wire a family members loft conversion (one bedroom and en-suite) and I am planning to run a 16mm t&e to a new 5 way DB (lights, ring main and electric 10KW shower) in the loft and needed to know if using a RCD as a main switch is allowed and to 17th edition?
Hi all
Why not just extend the existing top floor lighting and socket circuits? then all you'll need to do is run a feed up there for the shower.
There is really no need in a domestic installation to be running 16mm submains just to power a loft conversion, you could probably run 3 average houses on that without it even getting warm!
Absolute madness!! Running a 16mm sub-main and installing a separate 5 way CU for a 'Single'' bedroom with ensuite, when literary everything is there within reach to supply this additional bedroom, with the exception of the shower....
Reply to Loft conversion - RCD main switch query in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
ok cheers for the help lads
