Loft conversion - RCD main switch query | Page 3 | on ElectriciansForums
Discuss Loft conversion - RCD main switch query in the UK Electrical Forum area at ElectriciansForums.net
Hi all
Unsure where to post this so if this is in wrong section I apologise!
I have been asked to wire a family members loft conversion (one bedroom and en-suite) and I am planning to run a 16mm t&e to a new 5 way DB (lights, ring main and electric 10KW shower) in the loft and needed to know if using a RCD as a main switch is allowed and to 17th edition?
These Kind of threads really do make life worth living!!!
Reply to Loft conversion - RCD main switch query in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
ok cheers for the help lads
