G
Guest77
yes I have a 1720 and it comes with a carry case and a brand new ethos test calibration box, all leads and first class insured signed for delivery, if your interested pm me and we can have a chat.
Thanks for all the replies. I'll have a search on fleabay and the likes and see what I can find. I'm not after any fancy as I think most of those sound quite expensive. If I use it quite a lot then I will consider a better one, up to now this will just to get me by until I know I will use it often
Apart from the risk of buying stolen gear on fleabay there's always the old saying to consider "Buy cheap buy twice"Thanks for all the replies. I'll have a search on fleabay and the likes and see what I can find. I'm not after any fancy as I think most of those sound quite expensive. If I use it quite a lot then I will consider a better one, up to now this will just to get me by until I know I will use it often
you'd be daft to buy from an unknown source on ebay when mike's offerring you the top of the range megger , known to be kosher.
Get on to Mike or you're not a proper Geordie ye madheed.
You won;t need to upgrade from that tester mate
Quit now while you're ahead bonny lad. They don't call it the GALLOWgate end for nothing you knowplus trev, I'm not a Geordie, I'm a manc stealing your women :smug:
Pi know what you're both saying but money is a bit tight at the minute hence why I'm starting to do this extra work. This may not work out but I hope it does.
It sounds like you need to make sure of ALL your costs to get going before you do anything!
a manc could not handle a geordie woman. you couldn't even cope with the scouse rejects we sent up the ship canal to you.Pi know what you're both saying but money is a bit tight at the minute hence why I'm starting to do this extra work. This may not work out but I hope it does.
I appreciate you don't want to spend much money, but I guess you could say, what are you going to do if you can't get enough work to justify a better one? Sell your other kit and call it a day? Sorry to sound all negative and putting a damper on it.
For me, I set out to mean business and to make sure I get enough work, I didn't start out thinking I'll get some cheap kit then if it works out I'll upgrade, it just doesn't sound very committing IMHO.
yep...Ebay have some real bargains on MFT'S sometimes if you time it right !!!
All this is for extra work to top up my wage mate, circumstances have changed (for the better) and I need to make some extra quick cash over the weekends. The last I time I touched domestic properties was around 7 years ago. I may start doing this extra work and not like it, therefore I'm trying to keep my loses to minimum. I also said I don't want to spend much, that doesn't mean I won't spend much on a test kit.
