Can the main earth be run on the outside of a building from the MET to the consumer unit clipped direct?
Would it not need some form of protection
Discuss Main earth run outside? in the UK Electrical Forum area at ElectriciansForums.net
If its in black plastic conduit?Yes it can be, there is no specific regulation, but other regulations may apply such as protection against UV, fauna and protection against mechanical damage, depending on the circumstances.
Black Plastic conduit or would it have to be metal conduit its for my flat it would be at minimum two meters from the groundIf it is something you are planning to install then I would suggest some outdoor-rated conduit. Black usually is, but you may find other colours are also UV stabilised.
It might not need protection strictly by the regs, but you have to take in to account the risk of physical damage from accidents like wheely bins knocking it, or the local scroats nicking it as it looks like enough copper to buy a beer.
Lol?no problem just to clip it direct onto the wall. or could get british gas to just throw it from one point to the meter, just 20ft.of 10mm Gn/Y dangling.
Got any green and yellow paint?I'd paint the conduit green and yellow to avoid any future confusion. ?
bugger. what am i going to do with this gallon of green yellow striped paint then?You know that was a joke ? ?
I'll trade you for a couple of tins of tartan paint?bugger. what am i going to do with this gallon of green yellow striped paint then?
Reply to Main earth run outside? in the UK Electrical Forum area at ElectriciansForums.net
