Making off SWA | Page 4 | on ElectriciansForums
Discuss Making off SWA in the UK Electrical Forum area at ElectriciansForums.net
My house
Whats your preferred way? What you thinks easier? Any useful tools made for terminating it?
My way is to score with a junior.
Then when making off the gland I like to use an adjustable with slip joint pliers.
Then when stripping the inner to reveal the conductors, I use bending and a sharp blade.
Just a question on what tools and tricks you guys use to terminate it.
Cheers
To be honest i've never terminated SWA cable into a fitted gland, always measured off and glanded, then fit the whole terminated/glanded cable to the enclosure. As i've stated on previous occasions, we don't use the standard brass SWA glands on the bigger cables we use ''Top-Hat'' glands, that make work that much easier in tight and/or restricted locations etc....
Reply to Making off SWA in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
A lot of issues can be solved by giving the connections an extra push with the back side of a Stanley blade if they haven't quite mates properly.
davesparks
