Max zs equations | Page 2 | on ElectriciansForums
  • Thread starter brizospark
  • Start date
  • Replies 32
  • Views 26K
  • Tags
    max
Discuss Max zs equations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
so do i when i've got it next to me in a smelly kitchen cupboard with mft gripped between my arse and elbow, torch in gob,,,,,,,
divide Btype/46 Ctype/23 and Dtype/11.5
you mean divide 46/Btype 23/Ctype and 11.5/Dtype ?!
otherwise my Zsmax on light circuit on hager NCN110A C10 would have to be 23/10 = 0.43 but I am getting nowhere near that with measurements.
When I went to school (was a long time ago granted) 23/10 was 2.3.
No matter which way you do the calculation they come out the same....
To get 0.43 you would divide 10 by 23.....
perhaps the quick Qual course providers can do a new course on how to use a calculator properly!!!!
I must have missed the bit where qualifications were discussed.
Remember Apollo, you have members here ranging from those who have just left school right up to guys that have spent 40+ years in the industry, we all have to start somewhere.
Anyway, the good looking young chap in post 4 posted a nice, simple, clear guide to calculating maximum Zs values.
mmmmmm I was taking the preverbial:rolleyes::rolleyes::D!!!!!!
You keep telling yourself that last bit:), the post was spot on though....:)
Thanks for correction.
For C10 10A maxZs = 2.3. My measured Zs (26 light points, 3 floors) is within 1.70 - 2.19 range.
On higher side but acceptable, right?
The corrected maximum value for comparison with measured values is 1.84 Ohms.
Your measured maximum value should be equal to or below that value.
Why do you say your Zs value is 'within the range of' it should be the highest measured value at the circuit extremity.
Hi if you check table 41.3 in BS7671 you will see IQ Elecrtrical is correct, the values are in the far right column and are provided so you can work out any value not given in the table:
e.g. for a type C 60898 the equation is 23/In
if we take a value given in the table of In=6A then 23/6 = 3.83Ω
or for the B32 you mention a type B 60898 the equation is 46/In then In=32A so 46/32 = 1.4375Ω or as they have rounded it up to 1.44Ω
If we take a value not given in the table as an example of when to use this = type B 45A then type B's use 46/In so 46/45 = 1.02Ω
Don't forget the values in 7671 are not adjusted for temperature so you'll have to do rule of thumb, alpha or F to adjust accordingly or get them to pass!
The regs do not supply a calculation for BS88 etc in table 41.4 as the value is not universal for fuse type and the regs tell you to refer to the appropriate British Standard to determine its value.
I however knocked together an excel graph to plot the curve for BS88's as I had a 60A which is not given.
I can post it up if anyone is interested?
Hope this helps, this was my first post.
Jon.
Hi, here is the BS88 plot and one for comparison with type B 60898 the IEE give values for - you can see the BS88 moves around hence the IEE not wanting to publish any guidelines on its calculation, you can also see the values printed in BS7671 are rounded.
I would also comment that I have read several posts around where people are struggling to get their Zs value to comply with the regs value please don't forget that the rule of thumb 80% value in the OSG is not the only way as the use of the ambient temperature factors F and alpha can give you big differences as you can be out on one and not the other and the other way around depending on all the variables.
One Q how do you upload a file to a post, I could not see how to do it hence putting the images in directly.
Jon.
"please don't forget that the rule of thumb 80% value in the OSG is not the only way as the use of the ambient temperature factors F and alpha can give you big differences Jon."
How would you apply ambient factors F and alpha in practice?
What is the difference between the F and the alpha?
Thanks.
Reply to Max zs equations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks for that, good line of thought. My take is that safety is about protection of life/people/livestock hence the earth thing and protection of...
