Meter Tails 16mm 0r 25mm | Page 5 | on ElectriciansForums
Discuss Meter Tails 16mm 0r 25mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Talking with Tony Cable from the NICEIC the other day at the ELEX show in coventry.
There is talk of a pilot scheme to start where registered Sparks would be given the authority to remove main cut outs for isolation purposes, also in this capacity the sparks would have the facility to re-seal the cut out.
I can only assume that from the suppliers point of veiw, this saves the resources of their area engineers coming to re seal a installation after major works where a certificate has been issued.
In light of this position i can only assume that the sparks will be able to acsess the meter to insert CU tails and also reseal this as such.
As for mater- cut out tails??? well im guessing that it will be within the sparks re-mit to change but it will probably contine to be a gray area.
How do i personally get around this. Well i have previously changed a CU with the tails to the unit live using insulated pliers and a clean pair of boxers.
Would i ever do it this way again???? Not bloody likely!!!!
So i use a pair of these to grip the fuse :
http://www.hyperclaw.com/pic/products/vde_water_pump_L.jpg
I dont grip to hard so i break the carrier but it stops me getting a ****er!
I shield my face as i pull it
The experienced guys probably think its over kill but i have heard to many horror stories, i think the most importaint part is to pull the fuse in one smooth action to avoid arc-ing
The fuse should not arc at all if the load is isolated.
There are some DNO's that permit registered sparks to pull the cut outs and give seals as a temp until they get round to fitting the correct ones.
Even if the do eventually give permission for us to pull the cut outs, they WILL NOT give us permission to change any tails from the meter.
IMO.
IMO.
Yeah it shouldnt arc and its probably me being paranoid.
Your opinion as far as what the DNO's will and wont allow is probably better than mine
Can we re-cap.
To replace existing 16mm tails from the meter to the CU.
Break seal and pull the fuse - meter now dead
Break meter seal and replace old tails with new 25mm.
Replace fuse and meter cover plate.
That's two seals cut. Or you could (not so safe) just cut seal at the meter remove old tails and replace.
Point I'm making is that cutting the fuse seal only is not enough if you wan't to replace the tails from the meter to the CU. Another (compromise) is to pull the fuse and then put the exisitng 16mm tails from the meter into a Henley Block and then go out from there with correctly sized 25mm tails - then request the board to remove Henley block and put new tails into the meter at their leisure.
The present state of affairs is a nightmare for practising conscientious electricians. Anyone attempting to ring EDF or similar and hanging on the end of a phone listening to music and then being pused onto another department etc etc will know. It is time that either we as registered qualified Electricians are given the green light to cut seals or the suppliers allocate enough funds to have a team of technicians on stand by to remove and replace seals.
My solution is very simple. Electricians cut whatever seals are required to carry out the required work safely and then they fill in a form which they send to the supplier to inform them that the seals have been cut and require replacing.
this old dog argument is always brought up, but main points to note are:
you should NOT pull a service fuse if a seal is present or not
you should NOT alter any cables at service head no matter what size or condition they are
there is no excuse, if you are caught you can be prosecuted.
Do most people just do it - yes
Do I do it - yes
but everytime its done you must understand that you are breaking the law and if Dno decided to prosecute (which would most likely be under extreme circumstances) then you would lose.
Ive always stated that any partp registered electrician, upon joining a scheme should get as part of there joining fees a PTO cert and set of sealing pliers issued!
I agree with getting a re-sealiing kit when you join a scheme.
I always have a nagging doubt about leaving stuff un-sealed after i've worked. I spotted these a while ago whilst looking for a meter, the flag ferrules or the square lead ones on this site look really similar. Thinking about getting a kit, what do you reckon ? Security seals and pliers
I think it's safer to crimp after replacing the tails. Stops accidental or deliberate removal of the fuse or meter cover by anyone else, including an overzealous DIYer!
Just a point to mention, when i re-wired my own house, i pulled service fuse and broke seal on meter and put pretty new tails in, Juiced the board and went about my merry way.
I thought i had better show willing and placed a call to the DNO to let them know, especially as the tails were 70yrs old and about 4mm2.
I called them in April 2007, guess what i still havent seen sicht or sound of them.
I wouldnt like to be waiting for them on a job to pull a service fuse
Cheers Eon crap as always
Don't guidelines say when replacing a consumer unit you have to replace tails as well? And as you're doing that, you need to cut the seal to the meter to install the new 25mm tails.
Id be intrested to know the reference?
Check out "Essential Guide" on NIC website. 16mm tails are ok if all conditions are met. Use 25mm tails and you will definitely be ok!
I found this on the ESC website on the best practise guide
6. Main earthing and bonding and
meter tails​
6.1. The installer must verify, as a minimum, that:
a) the main earthing terminal of the installation is
connected to an adequate means of earthing
via a suitably sized earthing conductor,
b) the main protective bonding is adequate, and
c) the meter tails and the distributor’s equipment
have adequate current-carrying capacity.
Note. Some electricity distributors have requirements regarding
the earthing conductor, main bonding conductors and meter
tails that exceed the requirements of BS 7671.​
6.2. If any of conditions 6.1 (a), (b) or (c) is not met, the
customer should be informed that upgrading is​
required.
I'm about to change a consumer unit with 16mm tails, if the main fuse is 60 or 80 A then I should be okay, 16mm = 87 A.
Reply to Meter Tails 16mm 0r 25mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
