P
Plonker 3
Are the tails solid copper?
Multi core cable refer to where there is more than one conductor enclosed in a sheath, so cables such as T&E, SWA etc
Sorry.
With all the excitement, I ended up taking the picture to the wrong cables.
The correct cables are above the DNO 100A fuse and are grey and same size which is 10mm by the way.
Regards,
Albert
In second pic definitely looks like 25mm tails too
Do you know the size of your incoming fuse?
CSA is cross sectional area (not including sheath), what you have measured is the diameter including the sheath. Looking at those pictures I would put money on those being 25mm.Are we talking 25mm, 2.5cm CSA?
Resu, there's the ruler right next to it showing it's a 10mm, 1cm.
Apologies if I am missing something.
Regards,
Albert
For example if you cut one of the tails and looked at it end on you would be looking at an area or 25mm2 of copper.CSA is cross sectional area (not including sheath), what you have measured is the diameter including the sheath. Looking at those pictures I would put money on those being 25mm.
How can a level 3 trainee not know the difference between cross sectional area and outside diameter ?
Trying to tell by the ruler but it looks slightly over 10mm? More like 11mm
You are correct.
So what would one say the cable itself is? 9.0mm? If removing the sheathing!
Apologies to all for the CSA / diameter confusion.
I am utterly letting myself down and my tutors also.
Pretty sure this was mentioned in the class at some point.
I just got so used to thinking 1.0mm, 1.5mm and 2.5mm CSA as being it's width, that lead to all this confusion.
Many thanks to all that offered their comments, views and/or opinions.
Always learning.
I fell that the changing of ideas here on the forum, the typing of all the materials, sources of info and regulations is priceless and helps so much more. Undoubtedly a great addition of information to add to that of the classroom.
Thanks everybody.
Apologies if I was in any way a tad out of order.
Regards,
Albert
