meter tails over 10 meters best way to do it | on ElectriciansForums
Discuss meter tails over 10 meters best way to do it in the UK Electrical Forum area at ElectriciansForums.net
P
pablo4321
Hi just after a bit of advice,we are wiring a new build where the meter is, the tails will be coming from outside into the kitchen they will be coming up the wall to the ceiling along the the middle of the joists to the consumer unit in the wall what is the best way to do this
1) shall i run them in steel conduit and earth the conduit to the earth terminal in the meter.
2) do i need a overcurrent switch fuse in between
3) and is it acceptable to use just normal meter tails to run under the floor in the middle of the joist.
thanks for any advice.
TBH, you'll find that 16mm/3c is as cheap as 16/2, and why do you need 25mm if you're down fusing to 60 or 80A??
This is a pic of an armoured 16/3 made off into tails for just this purpose - about 10m between intake and CU, where the cable is run exposed internally on the joists.
[ElectriciansForums.net] meter tails over 10 meters best way to do it
Are you not meant to bury tails or run them through joists? Because I've seen this I'm talking about a domestic house where the meter is out side the property in a little hut about 2m away from fuse board but the tails are about 5m and the tails come in to the house go up buried in a wall then through some joist and down to a high level fuse board.
Oh my, unqualified people making comments on a subject unqualified people have no business playing with and people seeming to ignore the regs that require meter tails to be no more than 3m long, after that they become a sub-main and must be wired in an appropriate manner.
Running tails via conduit is a simple none-starter, so your left with SWA and Pyro. Pyro is clearly outside to price range of all but commercial installs these days in special locations so your left with SWA. Meter tails are required to be 25mm² and for the purposes of common sense I would personally and professionally suggest that the sub-main also be 25mm², regardless of the sub-main being fused down to 60A or 80A. There may come a time when they want a larger supply and so this would need to be rewired if in 16mm², not easy in a finished house.
The correct way to do this would be
Head > Meter > DP Isolator > Sub-main > RCD Main switch in CU
thanks rocking it thats looks neat, just another question the bit round the armour where you have earthed it where do you get them from and what they called thanks
It's actually just a 20mm conduit coupler!
And I take no credit for this at all, it was an idea that Tony gave to me elsewhere a couple of weeks ago (hence why I happen to have some pics!).
Sorry but I don't agree with this. Why should more money be spent on buying 25mm when you should be selecting the cable suitable for the fuse size and installation method. How can you know what is going to happen in the future. Design the circuit to what is there now and not what might be there in 20 years time.
Reply to meter tails over 10 meters best way to do it in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
