Module 202 revision | Page 3 | on ElectriciansForums
Discuss Module 202 revision in the Electrical Course Trainees Only area at ElectriciansForums.net
The voltage across B.
So, 15A through the top and bottom left 0.1Ohm and 5A through the top and bottom right 0.1Ohm
So dropping 2 * (15 * 0.1 + 5 * 0.1) = 4
Archy or anyone else with some grey matter, can you please explain this
if A is increased to 10A (not increased by 10) then surely A is 10A and B is 5A
i just dont understand why in your equation you have done 15*0.1 + 5* 0.1
15A is the total so how can you then do another 5A unless you thought it said increase A by 10, then it would give you 15A???
i would of thought the equation would be 15A (total) x 0.2ohms (total of right side) = 3V
HELP needed!!!!
Chris, if the current through A is increased to 10A, then the source is providing 15A in total, so 15A through the top & bottom left line resistances, and 5A through the other two.
Recall Kirchhoff's Law!!! :)
Reply to Module 202 revision in the Electrical Course Trainees Only area at ElectriciansForums.net
